Author Topic: Use AddinBroadcast in Tagged Values  (Read 10749 times)
Michael Proske
« on: March 12, 2012, 10:59:01 pm »
I have created a tagged value to use the AddinBroadcast Function
Type=AddinBroadcast;
Values=SiemensEnvironment.EA_OnElementTagEdit;
Then i created an event function to listen to the event.
public void EA_OnElementTagEdit(EA.Repository Repository, long ObjectId, String TagName, ref String TagValue, ref String TagNotes)
     TagNotes = "Hallo";
When i klick on the ellipse nothing happens. Any idea what is wrong.
Re: Use AddinBroadcast in Tagged Values
« Reply #1 on: March 12, 2012, 11:56:58 pm »
Did you define the tag as Type=AddinBroadcast in the definition?
[edit:] I tried to return notes/value. None did change. So: as usual. It's broken. Report a bug.
« Last Edit: March 13, 2012, 12:08:39 am by qwerty »
Michael Proske
« Reply #2 on: March 13, 2012, 12:20:02 am »
Yes i defined it correctly. The proposed ellipse button also appeared. But nothing happend. I will submit a bug (maybe i reach 100 bug reports befor summer ...)
Thanks for your support
« Reply #3 on: March 13, 2012, 12:34:41 am »
I'm only at 50+ but mainly because I gave up sending reports for all findings I had. For a lot of them I just found "Geert-arounds".
« Reply #4 on: March 13, 2012, 05:29:47 pm »
I'm afraid there's no way to "geert" around this one ;D
EA has to make the call, and not amount of database editing or other dirty tricks will make it do so.
What I think is that you only have to give it the name of your addin, not the complete path to the operation.
From the help:
Values=YourAddinName;
So if your add-in is known by EA by the name of "SiemensEnvironment", then that looks like what needs to be used.
If I find the time I'll try to experiment with it one of these days.
In this case an example would really help :-/
« Reply #5 on: March 13, 2012, 06:10:22 pm »
[size=18]...[/size]Geert
Guys!   This is "geerting" better and better!  ;D ;D
« Last Edit: March 13, 2012, 06:10:42 pm by PaoloFCantoni »
« Reply #6 on: March 13, 2012, 08:50:26 pm »
Sure. And EA does. But it does not take back the parameter values. So that's something to report.
Michael Proske
« Reply #7 on: March 14, 2012, 05:32:31 pm »
The answer from Sparx is
Hello Michael,
Thank you for your enquiry.
The "AddinBroadcast" tagged value type should only specify the name of
the add-in to be called - not the method.
E.g.
Values=CS_AddinFramework;
Not:
Values=CS_AddinFramework.EA_OnElementTagEdit;
Try removing the ".EA_OnElementTagEdit" part from your tagged value
definition.
Geert you are right with your tip. I did it and it works. qweryt what do you mean by it takes not back the parameter values ? I just put in
            TagNotes = "Notes";
            TagValue = "Value";
and it works correctly.
Is "geerting" a kind oy joke between you and Paolo  ;)
« Reply #8 on: March 14, 2012, 05:38:40 pm »
Hi Michael,
Glad to see you got it working.
PS. Yes the whole "geerting" thing is a joke :D
« Reply #9 on: March 14, 2012, 06:15:11 pm »
[size=18]...[/size]
Hi Michael,
If you look carefully, qwerty started it!
But it DID pique my fancy...
Good to see you got it resolved. looks like some cool functionality.
« Last Edit: March 14, 2012, 06:19:15 pm by PaoloFCantoni »
Michael Proske
« Reply #10 on: March 14, 2012, 09:18:35 pm »
I think it could be interesting to play around with it i will next try to raise a dialog to edit my tagged value. I give you input about the results.
