Author Topic: EA process remains after Repository.CloseFile()  (Read 6847 times)
Knut Paulsen
« on: March 14, 2012, 06:05:08 pm »
Hi Guys,
I have a problem getting rid of the EA.exe process after using the repository via the automation api. The following test code will open two different DBMS repositories, one using OpenFile2 and one using OpenFile and then close them again. After the two calls to CloseFile, both EA.exe processes appear in the task manager, but after my program exits, only one of them disappears, hard to tell which of the two processes that refuses to go away. Using C#, Win XP and MySql.
Any ideas?
try
                m_RepositorySource = new Repository();
                m_RepositorySource.OpenFile2(c_SourceConnection, "user", "password");
                m_RepositoryTarget = new Repository();
                m_RepositoryTarget.OpenFile(c_TargetConnection);
                m_RepositorySource.CloseFile();
                m_RepositoryTarget.CloseFile();
                Environment.Exit(0);
            catch (Exception ex)
                MessageBox.Show(ex.ToString(), "Something failed", MessageBoxButtons.OK);
Knut Paulsen
Re: EA process remains after Repository.CloseFile(
« Reply #1 on: March 14, 2012, 07:40:45 pm »
Actually, it turns out that the second process also disappears, but it just took forever. Maybe 5-10 minutes.
It is the Repository opened with OpenFile that disappear when my process exits, the one opened with OpenFile2 remains.
I'm still interested if anybody has ideas to why it takes so long before the process goes away.
Knut Paulsen
« Reply #2 on: March 14, 2012, 07:59:04 pm »
I have not been doing my homework :-)
Just discovered the Exit() method of Repository ...
« Reply #3 on: March 14, 2012, 08:36:33 pm »
Hmm, glad we could help ;)
« Reply #4 on: March 15, 2012, 12:17:45 pm »
Don't underestimate the discipline of reporting a problem in a coherent way...
I often formulate a question on various fora only to find that the formulation process actually leads me to the solution!  8-)
« Reply #5 on: March 16, 2012, 12:06:57 am »
I often find that after writing down my problem and submitting it a flash strikes me with a solution some minutes later. So I often deleted my post shortly after creating it.
