Author Topic: SQL query fails for field Constraint in table t_objectconstraint  (Read 3942 times)
gjvandijk
I tried to create a sql query on the t_objectconstraint table with a selection on field Constraint.
On an eapx file this works fine, but when I tried to use it on a sql server repository de query fails with error:Incorrect syntax near the keyword 'Constraint'.
SQL Query(simplyfied):
Select t_objectconstraint.*
FROM t_objectconstraint
WHERE Constraint = 'SOURCETABLE'
So it appears to met that Constraint is a reserved word for SQL server databases.
Is there a workaround for this?
Re: SQL query fails for field Constraint in table t_objectconstraint
« Reply #1 on: October 03, 2018, 01:59:38 am »
WHERE [Constraint] = 'SOURCETABLE'
