Author Topic: Saving/backup vbscripts  (Read 9866 times)
George..Brennan
« on: October 04, 2018, 08:52:09 pm »
Currently looking at export/backup user VBS-Scripts from the repository to the file system.
Has anyone tried this?
G.
Re: Saving/backup vbscripts
« Reply #1 on: October 04, 2018, 09:03:33 pm »
I wrote a script to do that.
https://github.com/GeertBellekens/Enterprise-Architect-VBScript-Library/blob/master/Framework/Tools/Script%20Management/SaveAllScripts.vbs
This way I can manage my scripts in a version control system.
George..Brennan
« Reply #2 on: October 04, 2018, 11:40:35 pm »
Thanks, Geert,
Just seen this, that's  an impressive and extensive body of code, I'll need time to review it before I can make real use of it - and learn some lessons  ;)
Meanwhile I've been diving in and taking a much less generic view with XML to handle the SQL, works for the moment.
FYI
option explicit
!INC Local Scripts.EAConstants-VBScript
!INC ESFA-ScriptLib.VBS-Utils
' Script Name: EA-Utils
' Author:  George Brennan (xxxxxxxxxxxx)
' Purpose: Export VBS scripts from the repository for versioning
' Assumes path of  of "{user}\Documents\VBS-Sparx\"
const basePath = "Documents\VBS-Sparx\" '-- root for output files
const dataNodes = "//EADATA//Dataset_0//Data//Row" '-- EA XML Elements
const K_GROUP2FOLDER = 0
const K_SCRIPT_FILE = 1
const K_SCRIPT_TEXT = 2
const K_DEBUG = true
main
sub main
   '-- prep for outputs
   dim wsh       : Set wsh = CreateObject("WScript.Shell")
    dim fso        : Set fso = CreateObject("Scripting.FileSystemObject")
   dim userProfile : userProfile = wsh.ExpandEnvironmentStrings( "%userprofile%" )
   dim path       : path = userProfile & "\" & basePath
   dim filePathName
    '-- Make an EA repository SQL Call and parse the return set as a DOM tree
    dim SQL
    SQL =    "SELECT g.Script as ScriptGroup, " & _
         "       cast(s.Notes as xml).value('(Script/@Name)[1]', 'varchar(max)') as ScriptName, " & _
         "       s.[Script] " & _
         "  from t_script s " & _
         " inner join t_script g on s.ScriptAuthor = g.ScriptName " & _
         " where cast(s.Notes as xml).value('(Script/@Language)[1]', 'varchar(max)') = 'VBScript' "& _
         " order by g.Script " '-- by target folder
    dim doc : set doc = CreateObject("MSXML2.DOMDocument")
    doc.validateOnParse = False
    doc.async = False
    doc.loadXML(SQLQuery(SQL))
   '-- Traverse the DOMDocument and output each script as a file
    dim rowSet : Set rowSet = doc.selectNodes(dataNodes)
   For Each row In rowSet
      '-- check group folder exists
      If not fso.FolderExists( path & row.childNodes(K_GROUP2FOLDER).text ) Then
         fso.CreateFolder( path & row.childNodes(K_GROUP2FOLDER).text )
      end if
      '-- build path/name and write file
      filePathName = path & row.childNodes(K_GROUP2FOLDER).text & "\" & row.childNodes(K_SCRIPT_FILE).text & ".vbs"
      dim oFile : Set oFile = fso.CreateTextFile( filePathName, True)
      oFile.Write ( "'" & vbNewLine & "'-- exported : " & FormatDateTime(Now, vbGeneralDate) & vbNewLine & "'" & vbNewLine )
      oFile.Write (row.childNodes(K_SCRIPT_TEXT).text)
      oFile.Close
      if K_DEBUG then Session.output(">> wrote: " & filePathName) end if
    Next
end sub
George
« Last Edit: October 04, 2018, 11:42:48 pm by George..Brennan »
