Author Topic: UML Elements for MDG Toolbox  (Read 4917 times)
MatthiasVDE
« on: October 08, 2018, 06:05:08 pm »
I want to fill my Toolbox with some UML elements. The standard UML elements are listed below, and I can add them to the toolbox by adding them as an attribute
to the stereotype.
e.g. UML::Actor for an Actor.
But what can I use to represent a 'Use' or an 'Include' association on a use case diagram? Is there a list available of ALL (not just UML) elements and relationships that I can add to the toolbox?
Connector names for Toolbox Page definitions
•   Abstraction
•   Aggregation (Aggregate)
•   Assembly
•   Association (Associate)
•   AssociationClass (Association Class)
•   CallFromRecursion (Call)
•   CommunicationPath (Communication Path)
•   Composition (Compose)
•   Connector
•   ControlFlow (Control Flow)
•   Delegate
•   Dependency
•   Deployment
•   Extension
•   Generalization (Generalize or Inheritance)
•   InformationFlow (Information Flow)
•   InterruptFlow (Interrupt Flow)
•   Invokes
•   Manifest
•   Message
•   Nesting
•   NoteLink (Note Link)
•   ObjectFlow (Object Flow)
•   Occurrence
•   PackageImport (Package Import)
•   PackageMerge (Package Merge)
•   Precedes
•   ProfileApplication (Application)
•   Realization (Realize or Implements)
•   Recursion
•   Redefinition
•   Representation
•   Represents
•   RoleBinding (Role Binding)
•   SelfMessage (Self-Message)
•   Substitution
•   TagValAssociation (Tagged Value)
•   TemplateBinding (Template Binding)
•   TraceLink (Trace)
•   Transition
•   UCExtend (Extend)
•   UCInclude (Include)
•   Usage
•   UseCaseLink (Use)
Element names for Toolbox Page definitions
•   Action
•   ActionPin
•   Activity
•   ActivityFinal (Final)
•   ActivityInitial (Initial)
•   ActivityParameter
•   ActivityPartition (Partition)
•   ActivityRegion (Region)
•   Actor
•   Artifact
•   AssociationElement (Association)
•   Boundary (for Use Cases)
•   CentralBufferNode (Central Buffer Node)
•   Change
•   Choice
•   Class
•   Collaboration
•   CollaborationOccurrence (Collaboration Use)
•   Comment (Note)
•   Component
•   Constraint
•   Datastore
•   Decision
•   DeploymentSpecification (Deployment Specification)
•   Device
•   DiagramLegend (Diagram Legend)
•   DiagramNotes (Diagram Notes)
•   DocumentArtifact (Document Artifact or Document)
•   Entity (Information)
•   EntityObject (Entity)
•   EntryPoint (Entry)
•   Enumeration
•   ExceptionHandler (Exception)
•   ExecutionEnvironment (Execution Environment)
•   ExpansionRegion
•   ExitPoint (Exit)
•   Feature
•   FinalState (Final)
•   FlowFinalNode (Flow Final)
•   ForkJoinH (Fork/Join - Horizontal)
•   ForkJoinV (Fork/Join - Vertical)
•   Gate (Diagram Gate)
•   GUIElement (UI Control)
•   HistoryState (History)
•   Hyperlink
•   InformationItem (Information Item)
•   InitialState (Initial)
•   InteractionFragment (Fragment)
•   InteractionState (State/Continuation)
•   Interface
•   InterruptibleActivityRegion
•   Issue
•   Junction
•   Lifeline
•   MergeNode (Merge)
•   MessageEndPoint (Endpoint or Message Endpoint)
•   MessageLabel (Message Label)
•   Metaclass
•   Node
•   Object
•   ObjectBoundary (Boundary)
•   ObjectControl (Control)
•   ObjectEntity (Entity)
•   Package
•   PackagingComponent
•   Part
•   Port
•   Primitive
•   PrimitiveType
•   Process
•   Profile
•   ProvidedInterface (Expose Interface)
•   ReceiveEvent (Receive)
•   Requirement
•   RobustBoundary (Boundary)
•   RobustControl (Control)
•   RobustEntity (Entity)
•   Screen
•   SendEvent (Send)
•   SequenceBoundary (Boundary)
•   SequenceControl (Control)
•   SequenceEntity (Entity)
•   Signal
•   State
•   StateMachine (StateMachine)
•   StateTimeLine (State Lifeline)
•   Stereotype
•   StructuredActivity (Structured Activity)
•   SynchState (Synch)
•   Table
•   Terminate
•   TestCase (Test Case)
•   Text
•   UseCase (Use Case)
•   UMLBoundary (Boundary)
•   ValueTimeLine (Value Lifeline)
Re: UML Elements for MDG Toolbox
« Reply #1 on: October 08, 2018, 06:57:52 pm »
use and include are both stereotyped associations.
MatthiasVDE
« Reply #2 on: October 08, 2018, 07:26:11 pm »
And how can I put these stereotyped associations into my toolbox?
« Reply #3 on: October 08, 2018, 08:00:45 pm »
•   UCExtend (Extend)
Isn't that what you are looking for?
MatthiasVDE
« Reply #4 on: October 08, 2018, 08:41:20 pm »
•   UCExtend (Extend)
Yes!
How could i look over that...
