Author Topic: Status property and tagged values for diagrams  (Read 7358 times)
jörg
« on: October 09, 2018, 07:30:47 pm »
For using diagrams in requirements engineering, it is needed to have at least a status property and tagged values in diagrams, as they are available in elements.
Maybe is should be possible to add an element reference to a diagram as packages have it (EA.Package.Element). In my opinion this can solve the problem since all element properties will be available to a diagram too, then and it should be able to do that without a database change (adding diagram to the t_object table).
Maybe there are more requirements engineers that have an opinion about that theme?
PeterHeintz
Re: Status property and tagged values for diagrams
« Reply #1 on: October 09, 2018, 08:18:03 pm »
+1 because I miss that feature e.g. to state if a diagram was already reviewed or not.
Best regards,
Peter Heintz
Ian Mitchell
« Reply #2 on: October 19, 2018, 07:34:12 pm »
+1 from me as well.
There all kinds of reasons to attach TVs to a diagram , for example, to remember its status (reviewed etc) so @Sparx this would be a great feature. Can't see a simple place to put them:
- t_objectproperties looks to have secondary key of the Object_ID, which would get confused with diagram_ID.
- t_xref - where all the strange new stuff seems to go...
Or
- t_diagramlinks - at least this will get tidied-up when the diagram gets deleted, but I've just tried this approach, and any new t_diagramlink rows don't get exported when we XMI the diagram.
- create an invisible element in the diagram, and give the TVs to that? Horrible :-(
Any requirement for this should probably include the ability to move the diagram between repositories.
Any more suggestions for how to do this?
www.eaDocX.com
www.theartfulmodeller.com
Ian Mitchell
« Reply #3 on: October 19, 2018, 07:43:16 pm »
There also seems to be somewhere in the XMI format where this data might fit, if @Sparx were to create a solution for us.
<diagrams> seem to have an <extendedProperties> tag, which is used by elements, but not by diagrams (at least in my examples) so there is a possibility that this might be used to hold diagram tagged values.
Needs a Sparx implementation though...
www.eaDocX.com
« Reply #4 on: October 19, 2018, 08:03:30 pm »
There is actually a table called t_taggedValue table that is used for parameter tags and connector role tags.
They should be able to use it for diagram tags as well.
Ian Mitchell
« Reply #5 on: October 22, 2018, 09:29:16 pm »
...never noticed that table before...
Looks like it's keyed on a GUID, so should do the job OK.
I guess we will have to do our own tidy-up, to delete entries here when a diagram gets deleted, but I'll give this a try.
I still that that the right way to do this is for @Sparx to deliver a solid solution.
www.eaDocX.com
philchudley
« Reply #6 on: October 23, 2018, 10:58:24 pm »
I too would like tagged values directly on a diagram.
In the meantime, there is a rather ugly workaround.
  • Drag a diagram as a Diagram Frame onto another diagram
  • Move this Diagram Frame to the same package as the Diagram
  • Make the diagram a child element of the Diagram Frame
Diagram Frames can have Tagged Values just like another elements, and of course you can use relationships to / from (for example realisation of Requirements)
Just a thought
Phil
Models are great!
