Author Topic: C# api, connect to server instead an EAP  (Read 4504 times)
Fabio Falci
« on: March 09, 2012, 03:21:10 am »
Hi!
Can I connect to a server instead an EAP?
Repository r = new RepositoryClass();
r.OpenFile("test.eap");
// r.OpenServer("connectionString"); ?
Thanks in advance.
Fabio
Fabio Falci
Re: C# api, connect to server instead an EAP
« Reply #1 on: March 09, 2012, 03:33:35 am »
The solution is to create an EAP shorcut and OpenFile this EAP.
* EAP shortcut: open EA, connect to server, go to 'File > Save Project Shortcut'.
Luis J. Lobo
  • IT Consultant
« Reply #2 on: March 23, 2012, 10:09:44 am »
From the "OpenFile()" EA help:
This is the main point for opening an Enterprise Architect project file from an automation client, and working with the contained objects.
If the required project is a DBMS repository, and you have created a shortcut .EAP file containing the database connection string, you can call this shortcut file to access the DBMS repository.
You can also connect to a SQL database by passing in the connection string itself instead of a filename. A valid connection string can be obtained from the Open Project dialog by selecting a recently opened SQL repository.
Parameters:
ยท Filename: String - the filename of the Enterprise Architect project to open.
