Author Topic: Diagrams in element compartment  (Read 4493 times)
Mats Gejnevall
« on: October 18, 2018, 01:34:19 am »
Hi all,
I want to be able to link an element to a number of diagrams and show all the linked diagrams in a compartment in that element. Then I should be able to click on any of diagram names in the compartment to display that diagram. Is that possible? Can I do a shape script to handle this? Or is it already possible in EA?
Mats
Re: Diagrams in element compartment
« Reply #1 on: October 18, 2018, 07:45:12 am »
You can create hyperlinks (context/Common/...) or drag diagrams directly on a diagram. In the latter case you can decide how to show them (as diagram frame, etc.). You can create links for all of them.
Sunshine
  • Its the results that count
« Reply #2 on: October 18, 2018, 07:46:01 am »
Yes you can create links from elements to diagram using links in properties of element but not seen the ability to put those links into compartments on the element within a diagram. It may be possible via shapescripts but I haven't seen it.
If you generated HTML you get to see the links.
Bit of a kludge but you could drag the diagram onto another diagram and create a hyperlink then overlay onto an element.
« Last Edit: October 18, 2018, 07:48:21 am by Sunshine »
Happy to help
OpenIT Solutions
« Reply #3 on: November 08, 2018, 04:09:11 am »
Hi Mats,
Where you able to implement this via a shapescript / compartments ? Its exactly what I'm after as well.
Jon.
Mats Gejnevall
« Reply #4 on: December 20, 2018, 07:15:10 pm »
I have tried it with shape scripts. I added a relation to the diagram (e.g. trace) and then added the attached shape script. It shows the diagram names in a compartment, but when clicking on the name of the diagram it brings up the diagram element, NOT the diagram itself. Maybe there is some shape script magic to fix this, I don't know. Or maybe I should add a improvement suggestion to EA.
     if(HasProperty("Connector.StereoType", "trace"))
         SetCompartmentName("Related diagrams");
         AppendCompartmentText("#Name#");
