Author Topic: debug mdg technology  (Read 4987 times)
SomersetGraham
« on: April 03, 2012, 08:34:10 pm »
Hi
I have an MDG technology in which I have created several toolboxes associated with different diagram types.
These contain the my  specialised sterotypes, but when I drag an item from the toolbox onto the diagram nothing happens, I can drag standard items onto the diagram.
Is there a good way of debugging the technology?
Using V12
Re: debug mdg technology
« Reply #1 on: April 03, 2012, 08:48:52 pm »
Uaaahahaha! A good portion of luck!
Honestly, this is black magic. Try re-saving all profile parts once again. That often helps (see also the thread below).
SomersetGraham
« Reply #2 on: April 03, 2012, 08:54:49 pm »
I have already tried that but to no avail!
You mentioned another thread?
Using V12
Makulik
« Reply #3 on: April 03, 2012, 09:00:45 pm »
I experienced the same thing with toolbox definitions for elements of the same metattype. The help says you should specify Toolbox items in the ToolboxPage using MyStero(UML::<Metaclass>). As soon I ommitted the (UML::<Metaclass>) part for Elements extending the same metaclass, it worked.
Günther
« Reply #4 on: April 04, 2012, 12:39:48 am »
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1332403645 which will not bring you further but shows another deficit in the MDG creation.
Usually when this happen then your toolbox refers to a not-existing profile element. Have a look into the xml and find the definition of the toolbox. It might be simple typo.
SomersetGraham
« Reply #5 on: April 04, 2012, 12:49:22 am »
I'll look into it
Using V12
