Author Topic: Reading data from imported MDG  (Read 6240 times)
tzafrir
« on: October 30, 2018, 07:34:24 am »
I imported MDG which included a customized dependency relation between stereotype A to stereotype B.
Now I want to get to that information (this dependency) when running the addin on the Model.
Is there an API that can read data from the MDG?
I did not find this data in the DB. Does anybody knows where it is kept?
Tzafrir
Re: Reading data from imported MDG
« Reply #1 on: October 30, 2018, 08:26:32 am »
No you can not access the MDG data from inside EA. Except you know where the XMI source is stored and read that file.
EXploringEA
« Reply #2 on: October 31, 2018, 02:58:55 am »
Hi
As Qwerty says only way to get the MDG information is to read the relevant files, note that there may be MDG files within Sparx Program files area e.g. "C:\Program Files (x86)\Sparx Systems\EA\MDGTechnologies"  as well as within the users appdata e.g. "\Sparx Systems\EA\MDGTechnologies\"  - that caught me out 1st time I did it.
You then need to parse the relevant files to extract the information you need.
Adrian
« Last Edit: October 31, 2018, 08:03:27 am by EXploringEA »
EXploringEA - information, utilities and addins
« Reply #3 on: October 31, 2018, 05:56:55 am »
If imported into a model I think it is stored in t_document. (but I could be wrong)
« Reply #4 on: October 31, 2018, 06:53:18 am »
Yes. And of course you don't know which profile EA takes: the one in the model, the one from the program folder or the one from the MDG/Advaced menu (that appdata-variant is new to me).
