Author Topic: Export of UML Profile via Autoamtion Interface  (Read 22200 times)
Makulik
Re: Export of UML Profile via Autoamtion Interface
« Reply #15 on: April 03, 2012, 08:20:01 pm »
sorry, missed that in the previous screeenshot.
this one should be better:
Lars
Hmm, not sure but could this be a restriction of your EA Edition??
I'm working with the latest Professional Edition (and Corporate at work) and the menu entry is definitely there.
Günther
« Last Edit: April 03, 2012, 08:20:31 pm by Makulik »
« Reply #16 on: April 03, 2012, 08:47:00 pm »
Lars,
you should start a thread in the Bugs list.
Lars J.
« Reply #17 on: April 03, 2012, 09:04:39 pm »
Günther
Although we have an ultimate edition it says that it is running as a professional edition - there seem to be problems with the licensing. I'll check if this is the reason.
Lars
Lars J.
« Reply #18 on: April 03, 2012, 09:37:27 pm »
Lars,
ok, I'll do that, because even after fixing the problem with my licenses (used accidentally the previous 8.0 professional instead of the 9.3 ultimate) the problem is still there.
Thanks for your patience.
Lars
« Reply #19 on: April 04, 2012, 09:06:42 am »
I just have implemented my own MTS-generation. Of course it does not help in exporting, but alone the fact that it checks the contents of a profile against its name saves me hours and hours. EA's MTS just plugs together files even though they contain the wrongly saved profile. I have just two profiles to maintain. But if you have so many you should consider implementing this MTS generator.
Have you tried using a merge utility such as WinMerge or Araxis? Each time before I build a technology, I use WinMerge to compare the current profiles with an archived version, checking what has changed in each file. If the answer is "everything" then I've saved to the wrong file and it's a single keypress to restore. I wouldn't be without it!
« Reply #20 on: April 04, 2012, 07:56:27 pm »
No. I use Perl to examine / merge the contents (I'm just used to that). But WinMerge is surely an option for others.
I hope my feature request is not too far off in the pipe. Basically MTS should verify or re-save the single profile files before building the new MDG.
Michael Proske
« Reply #21 on: April 04, 2012, 08:52:18 pm »
On behalf of the german team i will start a feature request  ;)
Michael Proske
« Reply #22 on: April 04, 2012, 09:04:20 pm »
Done.
