Author Topic: Is it possible to call Addin from shape script?  (Read 5412 times)
Roman Bretz
« on: April 04, 2012, 10:09:22 pm »
need to display some values not available via standard hasproperty method. Would be great if add-in calls could be used. Help says:
Properties for Element Shape Scripts
ยท addin (value returned from an Add-In)
Chapter "Display Element/Connector Properties"
but how??? I tried the call-syntax used in the code-generation templates - without success :(
« Last Edit: April 04, 2012, 10:11:06 pm by rbretz »
Roman Bretz
Re: Is it possible to call Addin from shape script
« Reply #2 on: April 04, 2012, 11:06:03 pm »
great, as usual - simple if you know how it works :)
thanks!
