Author Topic: Edge-Mounted Event size differs  (Read 4180 times)
Tafros
« on: November 02, 2018, 06:48:21 pm »
Hi all,
I am trying to place edge mounted event into a BPMN Activity.but edge mounted event size looking smaller in automation (EAScripting) while comparing with manual drag and drop option.Kindly share any fix for this!.
« Last Edit: November 02, 2018, 06:51:35 pm by Tafros »
Re: Edge-Mounted Event size differs
« Reply #1 on: November 02, 2018, 07:39:38 pm »
Which is your EA version?
Tafros
« Reply #2 on: November 02, 2018, 08:04:02 pm »
using EA 13.5
« Reply #3 on: November 02, 2018, 08:36:50 pm »
Not for me. I tried an ActivityParameter and I see no difference. Any add-ins running?
Tafros
« Reply #4 on: November 02, 2018, 09:15:34 pm »
Thanks qwerty.
Yes,Activity Parameter is creating with no difference.
I tried with Object Node,it having size difference.
Please check below code.
case otDiagram :
         // Code for when a diagram is selected
         var theDiagram as EA.Diagram;
         theDiagram = Repository.GetTreeSelectedObject();
         var ele as EA.Element;
         ele = Repository.GetElementByID(5602);
         var cele as EA.Element;
         cele = ele.EmbeddedElements.AddNew("Edge","ObjectNode");
         cele.Stereotype = "BPMN2.0::IntermediateEvent";
         cele.Update();
         var diaobj as EA.DiagramObject;
         diaobj = theDiagram.DiagramObjects.AddNew("","");
         diaobj.ElementID = cele.ElementID;
         diaobj.Update();
         break;
« Reply #5 on: November 02, 2018, 10:50:56 pm »
Yes. Looks like a bug you should report. Use the link in the Support section below and just reference this thread.
