Author Topic: How to get the Trigger-Data of a Timer event ? (C# script)  (Read 22853 times)
Re: How to get the Trigger-Data of a Timer event ? (C# script)
« Reply #15 on: November 13, 2018, 12:20:56 am »
You have to look into the correct t_xref records.
They are related to your Action based on the t_xref.Client = t_object.ea_guid
In your case there will be two t_xref records. One that indicates the type of Action, and the other that specifies the GUID of the trigger element.
So based upon that trigger element you will again need to query t_xref. One record specifies the kind of trigger (Time) and the other specifies the specification (0.5s)
On my test model they look like this:
XrefID Name Type Visibility Namespace Requirement Constraint Behavior Partition Description Client Supplier Link
{6FD0BC82-87EA-43dd-83B1-02EF301AB86B} MOFProps element property Public NULL NULL NULL event 0 RefGUID={89807AC7-D452-48eb-85EC-844975D3497B};RefName=0.5s; {F0E65A7D-D49C-47e1-B198-50B0F2D6C091} <none> NULL
{829EF67E-BDB8-444b-95C4-581AD0CEA054} CustomProperties element property Public NULL NULL NULL NULL 0 @PROP=@NAME=kind@ENDNAME;@TYPE=TriggerKind@ENDTYPE;@VALU=Time@ENDVALU;@PRMT=@ENDPRMT;@ENDPROP; {F0E65A7D-D49C-47e1-B198-50B0F2D6C091} <none> NULL
I'm not sure how much of this info can be read using the API objects purely.
« Reply #16 on: November 13, 2018, 12:39:04 am »
The API doesn't offer that (at least until 13.5; did not catch up with V14 but would not expect it anyway) so that way my advice to go to t_xref.
bd
« Reply #17 on: November 13, 2018, 09:25:01 pm »
Ok thank you. I will try it out :)
wahidovic123
« Reply #18 on: November 14, 2018, 08:06:16 am »
Subway Surfers Psiphon Hill Climb Racing
ok thank you for your reply
_________________
« Last Edit: November 14, 2018, 09:07:11 pm by wahidovic123 »
bd
« Reply #19 on: December 04, 2018, 02:11:09 am »
How can I get the values "0.5" & "Time" from the description. With parsing ?
« Reply #20 on: December 04, 2018, 03:01:03 am »
Uhm, what?
« Reply #21 on: December 04, 2018, 03:30:56 am »
Yes, you'll have to parse the contents of the xref records to get these values out.
(if indeed there is no way to get to it from the API objects. Since I haven't tested it myself I'm not 100% sure these values aren't available somewhere from the API)
bd
« Reply #22 on: December 04, 2018, 09:20:39 pm »
Ok, thank you.
bd
