Author Topic: Metadata Stereotyped Relationship  (Read 6570 times)
philchudley
« on: November 07, 2018, 03:10:19 am »
Hi All
I am developing  fairly complex MDG in EA 14.1 and am attempting to use the "new" quicklinker Stereotyped Relationship between two stereotyped elements defined in my profile.
It works, sort of.
When I create a diagram using my MDG, and use the Quicklink, I see the relationship defined in the Stereotyped relationship, BUT I also see the following
Substitution
Abstraction
Dependency
Information Flow
Realization
Usage
Trace
How can these be removed? Presumably somewhere within the MDG, these "extras" are not shown in ArchiMate 3.0 for example.
I don't really won't to revert to the legacy spreadsheet method!
Any help much appreciated
Phil
Models are great!
Re: Metadata Stereotyped Relationship
« Reply #1 on: November 07, 2018, 08:57:47 am »
Add the attribute _HideUmlLinks with initial value "True" to the <<metaclass>> element for the source stereotype.
philchudley
« Reply #2 on: November 07, 2018, 10:50:41 pm »
Many thanks KP
Much appreciated
Phil
Models are great!
« Reply #3 on: November 27, 2018, 12:44:24 am »
Any chance we can get this documented and implemented int he stereotype helper?
Just lost a couple of hours figuring out how to hide the standard UML links.
RoyC
  • Read The Help!
« Reply #4 on: November 27, 2018, 02:09:04 pm »
This will be in the next release of the Help. The _HideUmlLinks attribute is already there, I believe, in the Special Attributes topic, but I have added a reference in the Hide Default Quick Linker Settings topic as well.
Best Regards, Roy
« Reply #5 on: November 27, 2018, 03:30:21 pm »
It actually is documented in the help file, you are right.
Strange enough, searching for the exact string results in:
The search "_HideUmlLinks" did not match any documents
« Reply #6 on: November 27, 2018, 05:16:26 pm »
So the question is...  Why?
