Author Topic: Project transfer much slower when invoked from scripting  (Read 3506 times)
« on: November 08, 2018, 02:21:28 am »
I'm using EA 14.1 on an Oracle backend on a Citrix environment.
When doing a manual project transfer the whole thing take about 10 to 15 minutes to complete.
In the log file I can see that the first part, clearing the data in the target model, takes less then 3 seconds.
When doing the same thing from a script, the project transfer is an order of magnitude slower.
Clearing the data in the target model when doing it via a script takes minutes instead of 3 seconds.
I didn't even wait for the complete transfer to finish!
Does anyone know why this might be happening?
The script I'm using is the following:
'[path=\Projects\Project DL\DL Scripts]
'[group=De Lijn Scripts]
option explicit
' Script Name: Automated backup of EA project databases
' Author: Davy Glerum, Geert Bellekens, Tom Geerts, Alain Van Goethem
' Purpose: Automated Project Transfer from DBMS to EAP file as weekly backup. See end of script for different databases that are backed up.
' Date: 07/11/2018
sub DeLijnDEV
Dim CurrentDate
Currentdate = (Year(Date) & (Right(String(2,"0") & Month(Date), 2)) & (Right(String(2,"0") & Day(Date), 2)))  'yyyymmdd'
'dim repository
dim projectInterface
'set repository = CreateObject("EA.Repository")
Dim FileName
Filename = "EA_Export.eap"
dim LogFilePath
LogFilePath = "H:\backups\"&CurrentDate & " DeLijnDEV (back-up).log"
dim TargetFilePath
TargetFilePath = "H:\Backups\"&CurrentDate & " DeLijnDEV (back-up).eapx"
dim eapString
eapString = "DBType=3;Connect=Provider=OraOLEDB.Oracle.1;...;"
'get project interface
set projectInterface = Repository.GetProjectInterface()
projectInterface.ProjectTransfer eapString, TargetFilePath, LogFilePath
'repository.CloseFile
'repository.Exit
' Dim newFilename
' newFilename = "H:\Backups\"&CurrentDate & " DeLijnDEV (back-up).eap"
' Dim Fso
' Set Fso = WScript.CreateObject("Scripting.FileSystemObject")
' Fso.MoveFile TargetFilePath, newFileName
end sub
DeLijnDEV
MsgBox ("Back-up Finished.")
Anyone know a workaround to speed things up?
