Author Topic: Attribute descrption in v14  (Read 4447 times)
barikman
« on: November 13, 2018, 03:47:21 am »
Have just recently upgraded to EA v 14. I can no longer see how to provide description information for class attributes in the class properties dialog. Has this capability been removed, or is it somewhere else? I can't see any other posting on this subject, so apologies if this is a duplicate question.
Phil
Re: Attribute descrption in v14
« Reply #1 on: November 13, 2018, 09:58:00 am »
The notes for attributes can be edited in the docked notes window.
benc
« Reply #2 on: November 13, 2018, 10:06:32 am »
Hi Phil,
Just expanding on Simon's note and assuming you want to use the Notes field for the description information, the docked Notes window is available from the Ribbon: Start | Properties | Notes.
There's a Getting Started video that shows how you can use this window:
https://sparxsystems.com/resources/show-video.html?video=gettingstarted-editfeatures
(You could skip to about the 1 minute mark.)
Towards the end of the same video, there's some discussion about the all-in-one modal dialog which includes the Notes field and is probably what you're used to from earlier versions. As of EA 14.1 you can re-enable that modal properties dialog as the default editor.
There's another short Getting Started video that features the Notes windows here:
https://sparxsystems.com/resources/show-video.html?video=gettingstarted-createfeatures
Other similar videos here might be useful if you're upgrading between major versions of EA to EA 14.x:
https://sparxsystems.com/resources/demos/index.html?tab=getting-started
I hope that helps.
Ben
« Reply #3 on: November 13, 2018, 03:25:38 pm »
And if you want the old attributes dialog back you can set the option (from 14.1)
Start | Visual Style | Prefer Property Dialogs
Geerrt
barikman
« Reply #4 on: November 13, 2018, 09:43:17 pm »
Many thanks for the helpful replies.
Phil
