Author Topic: Transfer from SQL Server not possible  (Read 5273 times)
ngong
« on: November 15, 2018, 08:50:54 pm »
As usual I am preparing an .eap file with an empty model as a destination for a transfer. It has ~1.6kByte. After starting the transfer in the SQL Server model, I get the failure message "unrecognized database format". The .eap file size is reduced to 0kB, obviously corrupted by the transfer.
What I did just before? I Reset IDs as a measure to another problem.
Now, the model seems to be unusable. Do you know of recommendations to cope with EA in a robust way? What features not to use? One recommendation was not to use EA14, so I stepped back to 13.5. What else?
Rolf
Re: Transfer from SQL Server not possible
« Reply #1 on: November 15, 2018, 09:39:47 pm »
Have you tried starting from a (copy of) a previous backup?
ngong
« Reply #2 on: November 16, 2018, 03:16:33 am »
Thank you Geert.
I tried with a colleague - and he could run a transfer at his installation.
I install new - will give 14.1 a try - and now it works as expected.
Maybe the very long run "Reset IDs" over night and over VPN caused some problem.
Rolf
« Reply #3 on: November 19, 2018, 10:22:54 am »
With that size, it's too small to be a valid JET database/eap file.
Who gave you that bad advice? With what reason?
ngong
« Reply #4 on: November 29, 2018, 06:28:51 am »
Experimenting with checking Jet 4.0 and using the new extension .eapx instead of .eap, now it works.
The minimum .eapx file is - as you said Simon - roughly 2.4 MB.
Rolf
