Author Topic: DB error: table 'Schema.t_taggedValue' doesn't exist, found via RAS  (Read 10128 times)
Shegit Brahm
Hi there,
while exploring the world of RAS (Reusable Asset Service), I stumbled upon this error while I do the mandatory dependency check before registering an asset:
Microsoft OLE DB Provider for ODBC Drivers [-2147217865]
[MySQL][ODBC 5.3(w) Driver][mysql-5.7.24-0ubuntu0.16.04.1]Table 'EA_RAS_Client.t_taggedValue' doesn't exist
the creation code says:
CREATE TABLE `t_taggedvalue`
`PropertyID` VARCHAR(40) NOT NULL,
`ElementID` VARCHAR(40) NOT NULL,
`BaseClass` VARCHAR(100) NOT NULL,
`TagValue` MEDIUMTEXT ,
`Notes` MEDIUMTEXT ,
CONSTRAINT `pk_taggedvalue` PRIMARY KEY (`PropertyID` ASC)
ENGINE=InnoDB
DEFAULT CHARSET utf8
COLLATE utf8_general_ci
This page https://dev.mysql.com/doc/refman/5.7/en/identifier-case-sensitivity.html indicates, that there might be a problem with different OS and their settings - just the EA script uses only lower case.
And the DB also shows me the table, all lower case.
Any idea what I could do about it?
Searching for first error line brings up (mostly) "you are connecting to a mispelled table" - so the mysql statement might be all.
Just ... the table created by Sparx' script is lower case.
I would claim that after the initial setup, there was no such error.
Maybe it was only an error on one of three DB's and while I moved assets from a to b to c and vice versa - this error got "exported"?
Or is it a bug inside RAS feature?
Thanks, Shegit
Re: DB error: table 'Schema.t_taggedValue' doesn't exist, found via RAS
« Reply #1 on: November 16, 2018, 04:38:03 am »
Probably a bug. Best to report it to Sparx
« Reply #2 on: November 19, 2018, 10:24:20 am »
What build of EA are you using?
The error is the table name is case sensitive, and has been referred to wrong. I think it's already been corrected.
Shegit Brahm
« Reply #3 on: November 20, 2018, 07:49:18 pm »
I'm using build 1351. (Version 13.5.1351)
Sounds I can ignore it as it does no harm, just thinning my nerves as long as I think it harms?
« Reply #4 on: November 20, 2018, 08:04:38 pm »
Sounds like it would do harm if you actually used it.
AFAIK t_taggedValue is used to store tagged values for connector roles, operation parameters, and maybe a few others.
Shegit Brahm
« Reply #5 on: November 21, 2018, 12:08:48 am »
Sounds like it would do harm if you actually used it.[...]
Right now no error occured.
After this error report started, I set some tagged values, registered them, imported these assets somewhere else - and these tagged values got imported as well (and stored in the origin database).
Maybe I could create some own types and do more complicated stuff with tv to see if it gets broken.
On the other hand I do almost nothing in automation, so my explorative tests are clearly limited.
Cheers, Shegit
