Author Topic: APQC Process Model  (Read 7641 times)
Sunshine
  • Its the results that count
APQC Process Model
« on: November 17, 2018, 06:51:14 am »
APQC is a process framework for the full enterprise.
APQC's Process Classification Framework (PCF)® is the most used process framework in the world. It creates a common language for organizations to communicate and define work processes comprehensively and without redundancies. Organizations are using it to support benchmarking, manage content, and perform other important performance management activities.
https://www.apqc.org/pcf
For those who have requested it via PM I've published APQC process model on Git hub.
https://github.com/EASunshine/Sparx-EA
It utilises a custom Enterprise Architecture MDG that is also located there so you need to copy that into a folder and reference it via the MDG dialog set up in Sparx EA to get a proper view of the diagrams.
You also need to change preferences to show both alias and name to see both the ID and name. The ID is in the alias.
To access the metrics you need to enable the metrics window and you will see them when you click on certain process elements.
Enjoy  :)
Happy to help
RonSonntag
Re: APQC Process Model
« Reply #1 on: December 03, 2020, 04:37:43 pm »
Not sure if you are still monitoring this. I downloaded your GitHub and it looks like a really nice piece of work! Question: Do you have a process for updating the model with the current version of APQC, or, updating to use APQC retail?
Sunshine
« Reply #2 on: December 04, 2020, 04:44:42 pm »
Nah mate. Was a one off. Work in govt so retail wouldn't be of use to me either.
Don't have time at moment to update it either. Crazy busy at moment.
Happy to help
Sunshine
« Reply #3 on: December 04, 2020, 04:56:02 pm »
If memory serves i think i imported all the elements via spread sheet form apqc then manually shuffled the elements into a hierarchy and created diagrams
Happy to help
