Author Topic: Load audit trail file via API  (Read 5072 times)
Knut Paulsen
« on: April 16, 2012, 04:40:14 pm »
Hi guys,
The Repository object has methods for saving and clearing the audit trail log, but as far as I can see there is no method for loading an audit trail file.
Any suggestions?
Knut
Re: Load audit trail file via API
« Reply #1 on: April 16, 2012, 04:45:24 pm »
Zip it and put it back in the database?
Knut Paulsen
« Reply #2 on: April 16, 2012, 06:37:43 pm »
Thanks you Geert for a prompt response :-)
I'm not sure I understand how to do it though.
It appears to me that the audit trail is stored in the t_snapshot table and when I load an audit trail xml file, the individual entries appear in the t_snapshot table.
Are you suggesting that it is possible to zip the xml file and insert it into t_snapshot?
Cheers
Knut
« Reply #3 on: April 16, 2012, 07:01:34 pm »
It's just a suggestion to give it a try and see what happens.
« Reply #4 on: April 16, 2012, 08:32:39 pm »
There might be some base64 encoding involved as well.
If you search for "t_snapshot" in the forum there should be some pointers.
