Author Topic: Cover Page font problem  (Read 8432 times)
Venkatrao R
« on: November 28, 2018, 05:08:26 pm »
I have a cover page imported to my EA Tool. The font size is 18 in the cover page.
I duplicated EA's system Number Heading template and using for generating documentation.
After generating document, I saw that, font size is changed to 36 instead of 18.
If I don't use the numbered heading template, I'm getting 18 font size. But I have to use numbered heading template.
Please suggest the solution for this issue.
Thanks in advance.
Venkatrao R
Re: Cover Page font problem
« Reply #1 on: November 28, 2018, 06:02:53 pm »
Look into the stylesheets.
This is where you define all the styles, including the font size of the cover style.
By applying different stylesheets you can effectively use the same templates to generate a document in different house styles.
Venkatrao R
« Reply #2 on: November 29, 2018, 04:26:45 pm »
I already defined the font size required for my cover page in the style sheet.
But it is not applying to cover page at all.
Venkat
« Reply #3 on: November 29, 2018, 04:46:12 pm »
https://sparxsystems.com/enterprise_architect_user_guide/14.0/model_publishing/select_a_cover_sheet.html
Coverpages are "independent of the report template and Stylesheet you are using"
Venkatrao R
« Reply #4 on: November 29, 2018, 05:16:19 pm »
If I don't use the the style sheet, i'm getting the actual font what is there in the Cover page.
Once if I started using style sheet, the font size is changing.
« Reply #5 on: November 30, 2018, 06:02:05 am »
Try providing an example to Sparx Support (see bottom of this page for link)
