Author Topic: Reverse engineering for ODBC in MySQL  (Read 4061 times)
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« on: December 06, 2018, 09:13:27 am »
In a EAPX file I tried to reverse engineering a MySQL database in EA v 14.1 and the column types are wrong imported. For example, a column of type INT is mapped as type "494E54", which are the ASCII codes for the letters of the word INT (I=49, N=4E, T=54). The same happens for all the columns for all tables. It is the same when doing the reverse ODBC from the classic way or via "table diff" in the Database Manager.
Anybody having the same bug?
Re: Reverse engineering for ODBC in MySQL
« Reply #1 on: December 06, 2018, 09:32:57 am »
Did you try with 13.5?
« Reply #2 on: December 15, 2018, 09:17:34 am »
"SOLVED": The problem was the version of MySQL engine. Version 8.0 of the MySQL is not yet supported. You can only reverse older database by now.
If you can migrate your database to an older engine, then you can import it in EA.
