Author Topic: Creating table PKs with Javascript  (Read 4035 times)
davidn
« on: December 08, 2018, 03:21:31 am »
Hey,
I'm wondering how to create primary keys on tables with Javascript. I have a table and know which Attribute (var attr) I want to set the Primary Key as. However, the following code is not updating the Attribute to a PK:
attr.IsOrdered = true;
attr.Update();
theElement.Update();
theElement has Stereotype table and Gentype MySql.
Going into EA and then manually ticking the PK box on attr updates it to a PK.
Any insight? Thanks!
Sunshine
  • Its the results that count
Re: Creating table PKs with Javascript
« Reply #2 on: December 10, 2018, 06:29:30 pm »
If the JavaScript is becoming too much effort then an alternative path to get a quick result of  adding PK and FK might be to do a DDL transformation. However that adds new attributes.
Happy to help
davidn
« Reply #3 on: December 11, 2018, 03:27:38 am »
Thanks, guys.
Sunshine, how can I do the DDL transform you mentioned?
Sunshine
« Reply #4 on: December 11, 2018, 07:08:37 pm »
To do transform select package and from ribbon Design > Tools > Transform > Transform Selection
Apply Transform
Select classes
Select DDL Transform
Click Do Transform button
For detailed description see
https://sparxsystems.com/resources/user-guides/14.0/model-domains/model-transformation.pdf
Try the search its wonderful at finding things :)
Happy to help
