Author Topic: Activator.CreateInstance doesn't create second instance  (Read 3758 times)
Slávek Rydval
    • homepage
« on: December 08, 2018, 08:25:19 am »
I've got ASP.NET Core 2.1 app that is accessing EA repository. The code below works fine until I want to create another instance. When I use the code again, the current instance of EA is used, so I lose the connection to the first repository. Is there any witted solution to this problem?
EA.App eaApp = (EA.App)Activator.CreateInstance(Type.GetTypeFromProgID("EA.App", true));
eaApp.Repository.OpenFile(_repository);
EA.Element test = eaApp.Repository.GetElementByGuid(_testGUID);
Re: Activator.CreateInstance doesn't create second instance
« Reply #1 on: December 08, 2018, 05:36:08 pm »
You should be able to do something like this:
      EA.Repository r = new EA.Repository();
      r.OpenFile("c:\\eatest.eap");
See also: https://www.sparxsystems.com/enterprise_architect_user_guide/14.0/automation/automation_connect_setup.html
