Author Topic: find base classes  (Read 4387 times)
Maggie
find base classes
« on: April 20, 2012, 01:15:43 am »
Hi
Within my addin I am trying to find all the base classes for a given class.
so far I have
           foreach (EA.Connector connector in element.Connectors)
                 if (connector.Type == "Generalization")
                    EA.Element clientElement = Repository.GetElementByID(connector.ClientID);
This gives me a list of all Generalization connectors, including classes that derive from the target class.
What I need is only the classes from which the target class in derived.
I would be grateful if someone could give me some pointers
Maggie
g.makulik
Re: find base classes
« Reply #1 on: April 20, 2012, 01:49:05 am »
Check SupplierEnd, ClientEnd properties of the connectors (not sure which one actually) to filter out those connected on the 'right' end.
Günther
stao
« Reply #2 on: April 20, 2012, 03:12:00 am »
you can se this method.
public static ArrayList getBaseClasses(EA.Element classToGet, ArrayList returnList)
      EA.Element actClass = classToGet;
      returnList.Add(actClass);
      foreach (EA.Element actBaseClass in actClass.BaseClasses)
          returnList = getBaseClasses(actBaseClass, returnList);
      return returnList;
to use this method:
ArrayList classAndParents = getBaseClasses(classToFindParents, new ArrayList());
« Last Edit: April 20, 2012, 03:12:53 am by stao »
Maggie
« Reply #3 on: April 20, 2012, 04:46:52 pm »
Thanks!
« Reply #4 on: April 23, 2012, 09:33:09 pm »
My implementation is at https://github.com/GeertBellekens/Enterprise-Architect-Add-in-Framework/blob/master/EAAddinFramework/EAWrappers/ElementWrapper.cs basically the same:
   /// EA provides a shortcut tot the superclasses through its
    /// element.BaseClasses
    /// Normally we would get those via the element.generalizations.general
    public HashSet<UML.Classes.Kernel.Class> superClasses {
      get {
        return new HashSet<UML.Classes.Kernel.Class>
          (this.model.factory.createElements(this.wrappedElement.BaseClasses)
          .Cast<UML.Classes.Kernel.Class>());
      set { throw new NotImplementedException(); }
