Author Topic: RTF report : hierarchy of model not respected !!!!  (Read 3729 times)
vincentc
« on: April 18, 2012, 07:01:35 pm »
Hi.
I have a problem to make a RTF report of a model.
My model is composed like that:
metazone --> zone --> building block --> business service
So i would like the report to display something like that
metazone 1
zone 1
building block 1
business service 1   .......
metazone 1
zone 2
building block 1
metazone 2
zone 1
building block 1
business service 1
Unfortunatelly in the reports i have made, the order of the elements seems to be quite random.
Please help me.
Thanks.
« Last Edit: April 18, 2012, 07:18:26 pm by vincentcharrie »
RoyC
  • Read The Help!
Re: RTF report : hierarchy of model not respected
« Reply #1 on: April 20, 2012, 09:28:04 am »
Perhaps check the Document Options of the report or, if you are using a template you have created, the report template.
For the report, open the Generate Documentation dialog (click on package, press F8) and click on the Options tab and look at what is set in the Packages By and Elements By fields.
For the template, click on Settings | Document Template Designer: select the template and in the Content panel right-click and select | File | Document Options. Check the same fields as before.
Does that help?
Best Regards, Roy
Ian E Mitchell
« Reply #2 on: April 23, 2012, 11:36:11 pm »
No distrspect intended to the EA RTF generator, but if RTF can't produce what you want, have a look at eaDocX.
eaDocX - Document Generator for EA -  http://www.eadocx.com
