Author Topic: easier selection in Batch Document Generation  (Read 2881 times)
Oliver Otto
« on: April 13, 2012, 04:55:11 pm »
we are using the Batch Document Generation dialog to generate our documents. However, the model is split into various groups and subgroups. Therefore we have about a 100 documents to select in the Batch Document Generation dialog. The dialog has only a select/deselect all documents option, but I like to select only certain groups. I can mark with SHIFT-mouseclick all documents I like, but I have not found a way to check/uncheck the checkboxes of these elements. Has anyone an idea how to do this? Or is the a way to preselect only certain elements, as the current default is to select all documents?
Thanks already for any hint,
Oliver
Ian E Mitchell
Re: easier selection in Batch Document Generation
« Reply #1 on: April 23, 2012, 11:39:01 pm »
If you're serious about document generation, have you looked at eaDocX ?
eaDocX - Document Generator for EA -  http://www.eadocx.com
