Author Topic: EA crashes (exc 0xc0000409) when saving connector tag value too large  (Read 4817 times)
When trying to save (update()) an EA.ConnectorTag after setting the value to a string larger than 255 characters, EA crashes hard.
So hard you can't even catch the exception when debugging.
The exception code found in the eventviewer is 0xc0000409 which means STATUS_STACK_BUFFER_OVERRUN
I just spent a fun half a day tracking down this issue :-\
The API should catch this type of problem and return a regular COM exception instead of crashing and burning.
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
Re: EA crashes (exc 0xc0000409) when saving connector tag value too large
« Reply #1 on: December 14, 2018, 09:30:22 am »
You should report it as a bug
« Reply #2 on: December 14, 2018, 03:53:09 pm »
I did, don't worry  :)
