Author Topic: Have you tested on a DBMS MySQL 8 repository?  (Read 5556 times)
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« on: December 14, 2018, 09:29:09 am »
I have created a MySQL 8 repository but when users connected to the repository it throws database errors for every update/insert action that users execute in the user interface.
Do you think this is a problem related to the MySQL version? or could it be another weird missconsideration (as the Cloud Server config).
The environment is:
MySQL 8
ODBC driver 32 bits
Cloud server
Server contains: MySQLServer, Cloud Server, ODBC, Keystore server
Final users: EA 14.1 + TOGAF MDG. Floating licenses.
Re: Have you tested on a DBMS MySQL 8 repository?
« Reply #1 on: December 14, 2018, 10:24:58 am »
Sounds like you didn't check 'Return matched rows instead of affected rows'
See https://sparxsystems.com/enterprise_architect_user_guide/14.0/model_repository/setupmysqlodbcdriver.html
« Reply #2 on: December 14, 2018, 10:31:09 am »
I think it is checked (I usually don't forget to check the both options for mysql).
In another test, I had some issues when reverse engineering a mysql database. After several tests, I have just concluded that EA 14.1 does not work with MySQL 8 (in DB schema import from ODBC).
Tomorrow I will test the checks you said and with an older MySQL version (5.x)
« Reply #3 on: December 15, 2018, 09:14:29 am »
Today I tested on a MySQL 5.7.23 (with the suitable checks in the 32 bits ODBC connection) and it still fails. The ODBC driver I'm using is version 8.0.
Sunshine
  • Its the results that count
« Reply #4 on: December 16, 2018, 11:06:23 am »
It states the following in the user guide -have you tried reading it?
A machine with MySQL version 5 or higher installed and running,
MySQL 32bit ODBC driver, between versions 5.2.4 and 5.3.6 (other versions are not recommended)
https://sparxsystems.com/enterprise_architect_user_guide/14.0/model_repository/upsizingtomysql.html
« Last Edit: December 16, 2018, 11:09:44 am by Sunshine »
Happy to help
