Author Topic: using icons and menu separators on add-in  (Read 5092 times)
domi55
« on: April 26, 2012, 04:33:35 am »
Is it somehow possible to use icons and menu separators like in the following example within my add-in?
g.makulik
Re: using icons and menu separators on add-in
« Reply #1 on: April 26, 2012, 04:44:02 am »
I'm afraid that's not possible. AFAIK you can only manipulate your own menu entries using the EA_GetMenuItems() and EA_GetMenuState() callback methods. These don't support icon output parameters at all.
You might try to provide a separator returning an empty string with the EA_GetMenuItems() mehod.
Günther
domi55
« Reply #2 on: April 26, 2012, 04:55:38 am »
alright! thanks g.makulik!
« Reply #3 on: April 26, 2012, 05:07:20 am »
You can add separators. IIRC you need to send a '-' as entry. Just see the help.
domi55
« Reply #4 on: April 26, 2012, 05:29:33 am »
great! thanks very much!
« Reply #5 on: April 26, 2012, 03:07:21 pm »
And I've learned recently that you can also use checkbox thingies as well by setting IsChecked = true in the GetMenuState
