Author Topic: Default Element color fill in EA 14  (Read 9189 times)
Gomathi
« on: December 27, 2018, 10:26:54 pm »
When I create a flow chart element, it is in blue color by default.
How do I change it to the actual default element fill color?
I have disabled the 'Use Element Group Style' option in Preferences > Diagram > Appearance.
Is there any other option I have to give to change the default blue color fill?
Thanks in advance.
Re: Default Element color fill in EA 14
« Reply #1 on: December 27, 2018, 10:42:03 pm »
Hi Gomathi
Blue colour seems to be the default colour for flow chart elements . If you need to change the colour
From Ribbon  -> Layout -> Style ( change fill colour ) . ( Changes will affect in Diagram Level )
From Diagram -> Select the object -> press f4 -> change the fill colour. ( Changes will affect in Element Level )
EA usually store's background colour in Element Level and Diagram level .
Gomathi
« Reply #2 on: December 28, 2018, 12:13:06 am »
Hi Arshad,
I changed both the settings as mentioned.
But, when I create a new element, again it is created with the blue background.
« Reply #3 on: December 28, 2018, 03:42:00 am »
Yes because its the default color for Flowchart.
If you want to change to custom colors for FC elements you need to create a template package\Custom MDG and then should do the import.But in your case Template Package should do the trick .
- Using Template Package you can alter the default appearance of an element easily.
For creating Template Package refer https://sparxsystems.com/enterprise_architect_user_guide/14.0/modeling_tools/using_element_templates.html
« Last Edit: December 28, 2018, 03:55:59 am by Arshad »
Gomathi
« Reply #4 on: December 28, 2018, 04:27:39 am »
Hi Arshad,
Thanks a lot! I'm able to set the color and even default size of an element using template package. :D
« Reply #5 on: December 28, 2018, 03:15:51 pm »
Glad it helped :)
Gomathi
« Reply #6 on: December 29, 2018, 12:22:12 am »
Hi Arshad,
If I'm importing elements, then this template is not applied.
Is there any option I have to enable?
« Reply #7 on: December 29, 2018, 04:38:27 pm »
Which import are you using now ?
Gomathi
« Reply #8 on: December 29, 2018, 10:16:00 pm »
Hi Arshad,
I'm using MDG Excel import plug-in to import the elements.
« Reply #9 on: December 30, 2018, 04:06:59 am »
Hi Gomathi
In that case you can achieve setting the default colour for all the created objects by a simple post script .
case otPackage :
// Code for when a package is selected
var thePackage as EA.Package;
thePackage = Repository.GetTreeSelectedObject();
for(var i = 0;i<thePackage.Elements.Count;i++)
var ele as EA.Element;
ele = thePackage.Elements.GetAt(i);
ele.SetAppearance(1,0,3937500);
ele.Update();
break;
For more details on SetAppearance API call refer here.
For more details on SetAppearance property refer here
« Last Edit: December 30, 2018, 05:25:30 am by Arshad »
Gomathi
« Reply #10 on: January 14, 2019, 08:58:46 pm »
Hi Arshad,
Thanks! I just tried it today and it works.
Thanks for sharing the links for reference. I was able to set my preferred color.
« Reply #11 on: January 14, 2019, 09:17:54 pm »
Hi Arshad,
Glad it helped :D  :D :D
