Author Topic: Quicklinker  (Read 4017 times)
OpenIT Solutions
Quicklinker
« on: May 01, 2012, 10:17:51 pm »
I want to add the built in "BusinessRule" to the BPMN 2.0 quicklinker so my users can form a dependancy between an Activity and a BusinessRule. I added the following to the quicklinker in my MDG (an extension of the standard bpmn2.0) xml file...
Activity,Activity,BusinessRule,BusinessRule,BPMN2.0::Business Process;BPMN2.0::Choreography;BPMN2.0::Collaboration;BPMN2.0::Conversation;BPMN2.0::BPEL;,,,Dependancy,,to,,,TRUE,TRUE,TRUE,TRUE,Common,0,,,TRUE,,
This quicklinker still works - but it doesn't provide a link to a BusinessRule as i'd expect...any ideas why ? Could it be something to do with the "BusinessRule" being a type that is not defined in the same mdg file as the quicklinker in question ? In which case is there a way around ?
Jon.
OpenIT Solutions
Re: Quicklinker
« Reply #1 on: May 02, 2012, 02:52:52 am »
Solved myself - errors in the quicklinker text - BusinessRule has an object type of Requirement and dependency spelt wrong...
Re: Quicklinker
« Reply #2 on: May 02, 2012, 06:20:11 pm »
Personally I find debugging MDG and the Quick Linker in particular a real PITA. For just a single addendum it's sufficient to directly manipulate the MDG file (watch you comma!). But for developing larger QL blocks the procedure is a pain. Having done all the MDG creation steps you test the QL with the alternative works/works not. Instead of that embedded table there should be something like a model which can be checked via rules.
(Just dreaming)
