Author Topic: Adding new columns to UML class diagram  (Read 16833 times)
RogerVDK
« on: January 03, 2019, 01:01:42 am »
Is it possible to add new columns (besides the existing 6) under attributes in the UML diagram.
Re: Adding new columns to UML class diagram
« Reply #1 on: January 03, 2019, 01:24:11 am »
What do you mean by "columns under attributes"?
RogerVDK
« Reply #2 on: January 03, 2019, 01:32:15 am »
Dear Geert,
Thanks for your reply. I can send you a screenshot by email.
Best,
Roger
« Reply #3 on: January 03, 2019, 01:57:45 am »
Rather place the image on a public server (though that's a PITA) and post the link here.
« Reply #4 on: January 03, 2019, 02:08:17 am »
If you don't already have a favorite image hosting site, check out imgur.com, you can even copy/paste your image on that site, so the hassle it limited.
« Reply #5 on: January 03, 2019, 08:32:26 am »
My guess is you're talking about the Attributes tab on the Features & Properties window. In most tables in EA, if you want to see which columns are available you can right-click one of the column headings and use the Field Chooser command. Unfortunately, in this case it shows that the six columns you get by default are the only columns available (Name, Type, Scope, Stereotype, Alias, Initial Value).
RogerVDK
« Reply #6 on: January 03, 2019, 06:57:35 pm »
Many thanks for your reply. Here you can find the screenshot. https://imgur.com/a/bkCaMPa
Best,
Roger
« Reply #7 on: January 03, 2019, 07:57:21 pm »
Hi Roger,
As indicated by KP you cannot add any more columns to that view.
Are you looking to add new properties to an attribute you might want to look into tagged values.
If you are looking to show existing properties of attributes in an tabular way, you can use (SQL) searches to do that.
RogerVDK
« Reply #8 on: January 03, 2019, 11:05:31 pm »
Thanks a lot Geert.
Best,
Roger
