Author Topic: "Specialize>Technologies>Publish>Publish Package as UML Profile" not displayed  (Read 7487 times)
ThoWi
I have modelled a UML profile using several diagrams within a <<profile>> package.
When I bring up the "Specialize > Technologies > Publish" submenu, the menu entry "Publish Package as UML Profile" is not displayed at all, only "Publish Diagram as UML Profile" is displayed.
I have seen the forum issue about "Publish Package as UML Profile now working" (https://www.sparxsystems.com/forums/smf/index.php/topic,40206.msg246733.html#msg246733) and therefor I have a diagram open. But in my case the "Publish Package as UML Profile" is not displayed at all.
I am using EA v 14.1.1427
I't's a bug. The publish Package function is currently only enabled for Ultimate licenses.
It has been confirmed by Sparx and should be fixed in a next version.
For now you'll have to make due with the Publish Diagram (which works, but is not my preferred way of working either)
ThoWi
Thanks for the explanation!
satrman
Actually there is a workaround to this:
1. On any diagram, create a hyperlink
2. Change type to "EA Command" in Element Properties
3. Chose "SaveUMLProfile" command
4. Select Profile Package in Project Browser
5. Use your hyperlink
Note: If you select diagram, it will behave like SaveDiagramAsUMLProfile.
Cheers
Miloš Lang
