Author Topic: Cannot connect to a MySQL server  (Read 4816 times)
jepessen
« on: January 11, 2019, 02:57:51 am »
I'm trying to create a server-based project, on a MySQL server, with EA13.
These are my steps:
At first I've created the schema "enterprise_architect" and then I've created an user with all options allowed in that schema.
When program starts, I click on Server Connection, and the Data Link Properties window appear:
Then I select the Connection Tab, select the "Use Connection String" option and then I put the following string that I've calculated (user, server, pass are different of course).
Driver=MySQL ODBC 8.0 Unicode Driver;SERVER=my.server.ip;UID=myuser;PWD={my_password};DATABASE=enterprise_architect;PORT=3306;BIG_PACKETS=1;AUTO_RECONNECT=1
Then I click on Test Connection and the connection is tested.
After pressing OK, the Select Data Source window appears, that's strange for me since I've already set the data. Anyway I select the .dsn where I saved the same properties that I've set in the connection string. The content of the .dsn file is the following one:
[ODBC]
DRIVER=MySQL ODBC 8.0 Unicode Driver
UID=myuser
COLUMN_SIZE_S32=1
PORT=3306
SERVER=my.server.ip
After pressing OK the MySQL ODBC connector window appears. I set the data (again), test the connection and the test is ok.
I Press ok, the Connection Name & Type window appear, and then I set the project name and server data (AGAIN???), with DSN that, for me, is the connection string that I've set before:
At this point, I obtain the following error:
I've also tried to leave the final DSN field empty, but the error is the same...
What I'm doing wrong? How can I create this project?
Re: Cannot connect to a MySQL server
« Reply #1 on: January 11, 2019, 03:29:41 am »
EA is very particular when it come to MySQL driver versions.
Check the documentation and use the version specified.
« Reply #2 on: January 11, 2019, 09:52:06 am »
I'm by no means a database expert. Every time I've ever used an ODBC connection through those dialogs I've pre-configured a data source using odbcad32 (from syswow64) and then selected "Use Data Source Name". This results in me seeing the first two dialogs, followed by the first dark one, which allows for EA specific settings including a locally assigned name.
It appears that EA is looking for a named data source. Are you able to configure your connection that way?
jepessen
« Reply #3 on: January 11, 2019, 09:12:27 pm »
Yes, I've tried in your way and it works, thanks.
