Author Topic: Issue when turning off all MDGs except own  (Read 4926 times)
« on: May 15, 2012, 09:00:19 pm »
I guess there are not many using just their own profile with everything else turned off. However, here's my observation: every now and then EA decides to enable the Extended profile. This can be seen when hitting the space key on a diagram. On top of Other/MyProfile the Extended menu is offered. Also the QL shows entries which are not from my profile but likely taken from the Extended profile.
I have no clue when this happens. For a time it did not happen but today it is turned on each time I start EA. After dis-/enabling my profile the situation is cleared but only after the next EA restart when the Extended profile is activated once again.
Before sending a bug report I'd like to know if anyone else experienced this behavior.
Paulus
Re: Issue when turning off all MDGs except own
« Reply #1 on: May 16, 2012, 05:19:54 am »
Just to let you know: doing the same and so far causing no problems for me.
« Reply #2 on: May 16, 2012, 10:21:04 pm »
Thanks! Seems we're the only ones using EA this way. Hmm. What version are you using? Mine is 9.3 and I found this behavior in two different environments.
Could be it has to do with my profile since I have some strange other behavior (e.g. a stereotype "System" is created as "system").
