Author Topic: How to create connectors in transformation?  (Read 4554 times)
g.makulik
« on: May 17, 2012, 10:27:54 pm »
What exact syntax is needed to create a connector in transformation IL?
I have written an AddIn that generates the transformation IL bypassing any transformation templates besides 'File', in this template I'm just calling my function from the AddIn using the %EXEC_ADDIN()% macro to generate the IL.
I'm going to transform a StateMachine to a corresponding class model. Here's a simple example:
The states should be transformed to corresponding classes (which works fine), the transition connector should be transformed to a Dependency between the transformed classes. Here is the transformation IL I'm generating for this:
Class
      name = "StateMachine"
      language = "C++"
Class
      name = "State1"
      language = "C++"
      XRef
            source = "{3DC70348-DDA2-40fd-8C97-47FA5AAFF070}"
Dependency
      source
            XRef
      target
            XRef
                  source = "{FB4CF134-EBFD-412e-AE83-63EB2DB5E5DA}"
Class
      name = "State2"
      language = "C++"
      XRef
Dependency
      source
            XRef
      target
            XRef
But the Dependency connector isn't generated in the result  :( :
What am I missing??
Edit:
BTW, specifying name and namespace properties in the XRef elements doesn't help.
Günther
« Last Edit: May 17, 2012, 10:34:21 pm by g.makulik »
Re: How to create connectors in transformation?
« Reply #1 on: May 18, 2012, 08:08:03 am »
Well, if I was doing it in the templates I'd have
Class template
Class
TRANSFORM_REFERENCE("Class");
  name=%qt%%className%%qt%
  language="C++"
%list="Connector" @separator="\n"%
Connector template
Dependency
 %TRANSFORM_REFERENCE("Connector",connectorGUID)%
 Source
   %TRANSFORM_REFERENCE("Class",connectorSourceGUID)%
 Target
   %TRANSFORM_REFERENCE("Class",connectorDestGUID)%
Look at what that generates and see what you get.
g.makulik
« Reply #2 on: May 18, 2012, 08:08:18 am »
OK, think I found out myself. Seems that name and namespace properties in the XRef ARE relevant. Also added an XRef to the connector descriptions. Here's the IL code that works as I'm expecting (not sure if the connector direction property is really relevant somehow):
Class
      language = "C++"
Class
      name = "State1"
      language = "C++"
      XRef
            namespace = "C++STTCL"
            name = "State"
Dependency
      direction = "Source -> Destination"
      XRef
            name = "Connector"
            source = "{8E672976-9E34-4164-BA1D-19DB57986542}"
      source
            XRef
                  name = "State"
      target
            XRef
                  name = "State"
Class
      name = "State2"
      language = "C++"
      XRef
            name = "State"
Dependency
      XRef
            name = "Connector"
      source
            XRef
                  name = "State"
      target
            XRef
                  name = "State"
Thx to anyone who took the time reading this.
Günther
g.makulik
« Reply #3 on: May 18, 2012, 08:15:36 am »
Thanks for your answer Simon, seems we just posted at the same time.
Yes, that was more or less what I did. I've set up a simple example and used the C# standard transformation to inspect the IL output in detail.
WBR
Günther
