Author Topic: High CPU usage  (Read 4653 times)
pentaq
High CPU usage
« on: January 19, 2019, 02:43:06 am »
EA 12.1
Windows 10 on i7, 16GB RAM.
What can cause such high cpu usage? Not even project open, only EA running. All add-ons turned off. It's not only the case on my laptop. My workmates also report the same problem. EA just causes noise from venting CPU.
How can I check what part of EA is using extensively the processor?
Re: High CPU usage
« Reply #1 on: January 19, 2019, 03:10:25 am »
You seem to have a custom MDG loaded. Have you tried to remove this custom MDG file?
pentaq
Re: High CPU usage
« Reply #2 on: January 20, 2019, 04:52:55 am »
Do you mean custom made components on the left toolbar?
If so, how can these static (?) elements consume so much cpu?
Thanks for the answer though.
Re: High CPU usage
« Reply #3 on: January 20, 2019, 05:05:25 am »
If it's just the stereotypes defined in the MDG, then you're right. But often a MDG comes with add-ins that can run wild. Just try turning off the MDG (and any other unspecific MDG) to see if the problem persists.
q
Re: High CPU usage
« Reply #4 on: January 20, 2019, 05:13:07 pm »
I have no clue how or why, but
- you have the CPU problem and you have the custom MDG
- I don't have the CPU problem and I don't have the custom MDG
So it seems like the most obvious difference between you and me is the custom MDG (or toolbox), so the first step I would take it remove the most obvious difference and see if that changes anything.
Glassboy
Re: High CPU usage
« Reply #5 on: January 22, 2019, 07:09:34 am »
You don't actually know EA is the culprit.  It could be anything.
Install and run process monitor (https://docs.microsoft.com/en-us/sysinternals/downloads/procmon).  Open EA and see what is happening.
