Author Topic: Determine if Add-In is Loaded  (Read 3756 times)
« on: May 23, 2012, 01:52:17 pm »
I think this questionhas been asked before but I couldn't find an answer using search.
I need to determine if the BPMN Add-In has been loaded or not; since the BPMN object will render differently if it is loaded than when it is not.
That's reasonable...  However, since the effect on diagram rendering can be quite dramatic, I need to be able to tell if the Add-In is CURRENTLY loaded (remember since v9.3 Add-ins can be dynamically loaded).
TIA,
« Last Edit: May 23, 2012, 01:54:33 pm by PaoloFCantoni »
Re: Determine if Add-In is Loaded
« Reply #1 on: May 23, 2012, 03:53:10 pm »
There's no add-in involved.
I believe you want Repository.IsTechnologyEnabled ().
« Reply #2 on: May 23, 2012, 03:56:30 pm »
Paolo,
I think the info on which add-in to load is stored somewhere in the registry.
Of course that will only give you the info of which add-in is "supposed" to be loaded, not which one's are "actually" loaded.
PS. What you you mean by "add-ins can be loaded dynamically"? Or are you talking about MDG technologies?
« Reply #3 on: May 23, 2012, 05:42:26 pm »
Hi Simon,
My bad.  Since my Add-In installs one or more technologies, the distiction was moot for me. :-[
However, the Help for Repository.IsTechnologyEnabled () requires the supply of:
Parameters:
· ID: String - the technology ID to check for
Since the ID is internal to the MDG and not visible on the dialog, what is the technoilogy ID to be used for the BPMN MDGs?
Can the ID for the internal (Sparx supplied) MDGs be published please?
[edit]I think I've found them in the MDG XMLs - but it would be good to have that confirmed or, better still, formally published[/edit]
« Last Edit: May 23, 2012, 06:57:03 pm by PaoloFCantoni »
