Author Topic: Estimation factors  (Read 3305 times)
Knut Paulsen
Estimation factors
« on: May 24, 2012, 06:08:22 pm »
Hi guys,
I have a problem with the estimation factors for the use case points calculation that I hope you can help me with.
Ideally, I would like to be able to specify the ECF and TCF parameters on a per folder basis rather than for the entire project. Realizing that this is not possible in EA, I was thinking about keeping my ECF/TCF parameters in a separate table or file and then do multiple use case points calculations and then just add the individual results. There seems to be two problems with this approach:
1) I cannot find a way to manipulate the ECF/TCF factors using the API. I could of course go directly towards the t_ecf and t_tcf tables, but an API solution is preferable.
2) Also, I cannot find a way to trigger the use case points calculation via the API.
Any ideas? Grateful for any help :-)
Cheers
Knut
