Author Topic: Adding tags to a Transition connector  (Read 4401 times)
Mats Gejnevall
« on: January 23, 2019, 09:20:15 pm »
I have added some tags to my Transition connector in my MDG. But how can I set the tag values on the connector. I have not found any way to show the tags window on a Transition connector!!
Re: Adding tags to a Transition connector
« Reply #1 on: January 23, 2019, 09:30:50 pm »
If you open and dock the tagged values window somewhere it should show the tagged values of the connector once you select it in a diagram.
Mats Gejnevall
« Reply #2 on: January 24, 2019, 12:15:19 am »
No, it does not work for a Transition connection. The only thing that shows up in the Tagged Value window is stateFlow.
If I change the connector type to Association in my MDG, it works fine!!
Maybe it is a bug or some kind of UML feature?
« Reply #3 on: January 24, 2019, 12:35:15 am »
Have you tried to use stateflow as the base meta-class?
