Author Topic: How to apply a stereotype to multiple elements at once?  (Read 9246 times)
netizensmith
« on: January 24, 2019, 04:48:34 am »
Can this be done? Or do I have to manually paste the stereotype name 200 times into each of my requirements!?
Sunshine
  • Its the results that count
Re: How to apply a stereotype to multiple elements at once?
« Reply #1 on: January 24, 2019, 06:13:07 am »
Yes you can use script. Covered in previous post. Search for "Stereotype bulk change" and you should find this
https://www.sparxsystems.com/forums/smf/index.php/topic,39510.msg243782.html#msg243782
Which references the script here
https://sparxsystems.com/forums/smf/index.php/topic,30653.msg223132.html#msg223132
Just copy and paste script into Sparx. Modify the script to modify the stereotypes you want to apply.
« Last Edit: January 25, 2019, 07:29:27 am by Sunshine »
Happy to help
netizensmith
« Reply #2 on: January 25, 2019, 12:03:46 am »
Nice one, that worked a treat (after adding some supporting code for the Enumerator() and other ancillary functions that I found in some EA example scripts).
many thanks.
