Author Topic: .EAP vs .EAPX  (Read 7665 times)
José Farinha
.EAP vs .EAPX
« on: January 26, 2019, 05:55:58 am »
Anyone knows if there is any advantage in storing a project in a EAPX file, instead of EAP?
Is it advisable to migrate models from EAP to EAPX?
Thanks in advance.
Re: .EAP vs .EAPX
« Reply #1 on: January 26, 2019, 09:08:02 am »
IIRC EAPX==Jet4 (what an expression). It had been explained here on the forum by some Sparxians.
Sunshine
  • Its the results that count
Re: .EAP vs .EAPX
« Reply #2 on: January 26, 2019, 09:20:12 am »
EAP is basically MS Access 97(jet v3.5) and EAPX is MS Access 2003 (jet v4). You can look up the differences via a search on Google. If I recall correctly its faster, allows for bigger database and more concurrent users.
Happy to help
Re: .EAP vs .EAPX
« Reply #3 on: January 26, 2019, 04:39:14 pm »
Most important difference: eapx (jet4) has full unicode support.
There is also a difference in the SQL syntax they accept. Jet4 is less picky in that regard.
