Author Topic: lock/unlock History  (Read 8752 times)
Gujarish
lock/unlock History
« on: February 04, 2019, 09:23:16 am »
Hello everyone,,
For an SQL Server based upcoming movies netflix free trial free netflix EA model I enabled security with "Require User Lock to Edit".
Would it be possible to record all locks and lock releases together with the users issuing that function?
« Last Edit: February 07, 2019, 04:50:49 pm by Gujarish »
Re: lock/unlock History
« Reply #1 on: February 04, 2019, 04:27:33 pm »
No, I don't think so. (unless you would add triggers to the database; don't do that)
Why would you be interested in something like that?
ngong
« Reply #2 on: February 07, 2019, 01:59:34 am »
Hi, Gujarish - if you find a solution, please come back an tell us.
I would need it to relate any lock with a change request.
I tried to use the SCC interface (with PTC, also one try with non-SCC SVN) but run in problems of lost links between packages when they are different configurable items.
Rolf
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« Reply #3 on: February 08, 2019, 05:31:18 am »
I think it is a better idea to version-control the packages, and use the version control history as audit. I know this is not the same as you requested, buy maybe it could work for you.
ngong
« Reply #4 on: February 09, 2019, 05:11:03 am »
… except that the interface from EA to version control is not reliable.
Sometimes links between elements of separately versioned packages disappear. Also elements from diagrams may disappear if the diagram is owned by a package separately controlled as the one the elements is in.
Rolf
