Author Topic: Problem with the borderwidth setting in an MDG  (Read 3574 times)
« on: February 13, 2019, 06:43:33 pm »
There seems to be a problem with the borderwidth setting in an MDG.  If (say) this is set to 5 in the MDG, then in a diagram, this can be changed using the styling widget.  For values of 2-4, then all is good.  However, if you try to set the value to 1, then the diagram actually draws a width 5 line!   Please rectify.
Reported,
