Author Topic: Schema Composer: restrict property broken when multiplicity is set to *  (Read 3869 times)
If you set
  • in the multiplicity of the target role of an association the schema composer translates that to lowerbound = * + upperbound = *
So when I try to restrict this property I can only change the upperbound, but not the lowerbound.
When setting the multiplicity to [0..*] in the association (which has the same meaning as
  • ), the schema composer interpretes this correctly and allows me to change both upperbound and lowerbound in the restrict property dialog.
Bug reported.
