Author Topic: compensation in BPMN  (Read 5763 times)
aretai
« on: February 14, 2019, 02:57:19 am »
I've tried virtually everything, but I can't find a way to enter compensation into my BPMN model for example like the ones found on this website - https://docs.camunda.org/manual/7.4/reference/bpmn20/events/cancel-and-compensation-events/.  Can anyone help me with this feat?
Thank you
Re: compensation in BPMN
« Reply #1 on: February 14, 2019, 03:31:44 pm »
It's actually quite simple.
Add an intermediate event and choose for "Compensation".
You can change the type later in either throwing or catching compensation event.
Not sure what you are having trouble with. Are you sure you are using BPMN 2.0?
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« Reply #2 on: February 15, 2019, 12:43:03 am »
According to the diagrams of your link, be sure of:
1. Use the Toolbox: BPMN 2.0 / BPMN 2.0 Business Process
2. Use intermediate events type "compensation", inserted as "Edge mounted" to a previously created activity
3. Create an abstract activity and then change the tag values in order it become "compensation" (IsForCompensation = true)
aretai
« Reply #3 on: February 15, 2019, 02:02:56 am »
Thank you.  I just did that.  The problem is when I try to connect edge mounted compensation to an abstract activity with IsForCompensation=true.  I then try to select Sequence Flow To and I got an error: BPMN: Invalid source for the Sequence Flow.
Thank you
« Reply #4 on: February 15, 2019, 02:17:56 am »
You have to link them with an association.
Sequence flow is not allowed according tot he BPMN specs (see BPMN 2.0 specs page 255)
aretai
« Reply #5 on: February 16, 2019, 02:04:25 am »
Thank you for information
