Author Topic: how to mark sequence flow as the default  (Read 6425 times)
aretai
« on: February 16, 2019, 02:47:50 am »
I have the following problem.  I can't mark sequence flow as the default.  I tried virtually everything, checked every property of the line, but it doesn't show up. Please let me know how to achieve that step by step.
Thank you
Re: how to mark sequence flow as the default
« Reply #1 on: February 16, 2019, 03:16:13 am »
As default for what and where?
« Reply #2 on: February 18, 2019, 08:37:22 am »
If you are talking about BPMN sequence flow, set its tagged value conditionType=Default.
aretai
« Reply #3 on: February 21, 2019, 03:03:28 am »
Where do I find tagged value conditionType in the sequence flow?
Thank you
« Reply #4 on: February 22, 2019, 08:49:17 am »
Thank you
In the Tagged Values window. In EA 14, go to ribbon|Start|Explore|Properties|Tagged Values to open the Tagged Values window, or press Ctrl+Shift+6. It's worth having that window docked all the time when modeling with BPMN because a lot of the properties are defined as tagged values.
aretai
« Reply #5 on: February 28, 2019, 03:03:16 am »
Thank you it worked.
