Author Topic: How to update a tagged value of an element in a VB script ?  (Read 3257 times)
Domoina
« on: February 28, 2019, 09:44:22 pm »
I'm trying to update the tagged value of an element in a VB script like below :
(the tagged value is empty at the beginning)
        element.TaggedValues.GetByName("myTaggedValue").Value = "1"
element.TaggedValues.Refresh
        element.Update
But it doesn't work, the tagged value is still empty (even after the reload of the diagram).
So I tried with a SQL query :
        sqlUpdate="UPDATE t_objectproperties set Value= '1' where Object_ID = " & element.ElementID & " AND Property = 'myTaggedValue'"
Session.Output sqlUpdate
Repository.Execute(sqlUpdate)
But I get an error : DAO.Database [3144], syntax error in Update instruction.
What I get in the Output is :
UPDATE t_objectproperties set Value= '1' where Object_ID = 3161 AND Property = 'myTaggedValue'
I tested the query on a PostgreSQL database and it works well.
What I'm doing wrong ?
« Last Edit: March 01, 2019, 12:20:06 am by Domoina »
Re: How to update a tagged value of an element in a VB script ?
« Reply #1 on: February 28, 2019, 10:47:23 pm »
You have to update() the tagged value, not the element.
Try this:
dim myTag as EA.TaggedValue
set  myTag = element.TaggedValues.GetByName("myTaggedValue")
myTag.Value = "1"
myTag.Update
Domoina
« Reply #2 on: March 01, 2019, 12:19:02 am »
Works like a charm  :)
Thank you Geert
